Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 45 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
  • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
  • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
  • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
Mit der Spitze eines Spudgers kannst du die drei AirPort-Antennenkabel aus ihren Buchsen auf dem AirPort-Board herausziehen.
[* black] Use the tip of a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
[* icon_caution] The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
[* icon_reminder] To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
