Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Remove the single Phillips screw securing the inverter to the logic board. Lift the inverter straight up off the pins on the logic board.
  • Remove the single Phillips screw securing the inverter to the logic board.
  • Lift the inverter straight up off the pins on the logic board.
  • Be sure to lift the inverter straight up off the logic board, as the connector pins are very long and easily bent. If the pins bend during removal, use the connector on the inverter as a guide to bend them straight.
Hier Übersetzung einfügen
