Englisch
Deutsch
2. Schritt
One more screw on the bottom, underneath the manufacturer's label. Start spitting the case from the battery compartment. You can use a plastic opening tool, or your finger nails. It does bind a bit at the USB port side, but will separate pretty quick. With the back removed, the large LCD becomes immediately visible. There are no fasteners, it just rests inside the tray.
  • One more screw on the bottom, underneath the manufacturer's label.
  • Start spitting the case from the battery compartment. You can use a plastic opening tool, or your finger nails. It does bind a bit at the USB port side, but will separate pretty quick.
  • With the back removed, the large LCD becomes immediately visible. There are no fasteners, it just rests inside the tray.
Hier Übersetzung einfügen
