Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the throttle body from the engine. Remove the cover plate by prying up on the edges with a small screwdriver.  It is glued down with silicone. Under the cover plate you will see a computer module that is also siliconed in place. Remove the throttle body from the engine. Remove the cover plate by prying up on the edges with a small screwdriver.  It is glued down with silicone. Under the cover plate you will see a computer module that is also siliconed in place. Remove the throttle body from the engine. Remove the cover plate by prying up on the edges with a small screwdriver.  It is glued down with silicone. Under the cover plate you will see a computer module that is also siliconed in place.
Volvo throttle body servicing
  • Remove the throttle body from the engine. Remove the cover plate by prying up on the edges with a small screwdriver. It is glued down with silicone. Under the cover plate you will see a computer module that is also siliconed in place.
Hier Übersetzung einfügen
