Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 12
Using a flat head screwdriver press the tabs on the inside of the primer bulb assembly. (This will release the primer bulb from the housing) Pull the damaged primer bulb out of the engine housing Use long needle nosed pliers to disconnect the (2) fuel lines from the primer bulb.
  • Using a flat head screwdriver press the tabs on the inside of the primer bulb assembly. (This will release the primer bulb from the housing)
  • Pull the damaged primer bulb out of the engine housing
  • Use long needle nosed pliers to disconnect the (2) fuel lines from the primer bulb.
Hier Übersetzung einfügen
