Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Orient the Vive so that the camera is facing towards you and the connector ports are facing upwards. There are four screws you need to remove that are covered with small black stickers (two on top, two on bottom). Use a plastic opening tool to gently pry up the left side of the outer sheath.
  • Orient the Vive so that the camera is facing towards you and the connector ports are facing upwards.
  • There are four screws you need to remove that are covered with small black stickers (two on top, two on bottom).
  • Use a plastic opening tool to gently pry up the left side of the outer sheath.
  • If the left sheath is glued down, slide your plastic opening tool along the middle seam to break the bond.
  • Slide the left side of the sheath outwards.
Hier Übersetzung einfügen
