Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 2
Use a plastic opening tool to gently pry around the seam between the eyepiece housing and the screen. Gently pull the screen cover away from the eyepiece housing, threading the ribbon cable through the hole. Gently pull the screen cover away from the eyepiece housing, threading the ribbon cable through the hole.
  • Use a plastic opening tool to gently pry around the seam between the eyepiece housing and the screen.
  • Gently pull the screen cover away from the eyepiece housing, threading the ribbon cable through the hole.
Hier Übersetzung einfügen
