Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws. There should be a gap on each side to fit the Opening Tool.  Use the Opening Tool to open the back cover (Soft Touch cover) using the gap. There should be a gap on each side to fit the Opening Tool.  Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
  • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
  • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
Hier Übersetzung einfügen
