Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
The screen may crack during removal, so be wary of broken glass. Apply heat as necessary around the edges of the screen to loosen the adhesive, but be careful not to melt the plastic frame of the tablet. Starting on the side of the tablet near the bottom, heat the area and insert a metal jimmy or opening pick between the digitizer and the frame.
  • The screen may crack during removal, so be wary of broken glass. Apply heat as necessary around the edges of the screen to loosen the adhesive, but be careful not to melt the plastic frame of the tablet.
  • Starting on the side of the tablet near the bottom, heat the area and insert a metal jimmy or opening pick between the digitizer and the frame.
  • Separate the adhesive on the bottom of the tablet first, then work up the sides. The digitizer ribbon cable is located at the top and passes through a slot in the mid-frame. It is easily torn or damaged in the final stages of removing the glass.
  • If the glass is intact and you intent ro reuse it, take care not to insert the jimmy further than the width of the black screen border or you risk damaging the digitiser, which is a thin plastic film stuck to the bck of the glass.
  • The adhesive tends to stick to the plastic mid-frame rather than the glass but it will separate more easily and cleanly from the midframe if you can start it lifting at one point. This will also reduce the risk of damaging the digitiser film.
Der Bildschirm kann beim Entfernen brechen, vorsicht also vor gesplittertem Glas. Die Kanten des Bildschirms so stark wie nötig erwärmen, um den Kleber zu lösen. Aber vorsichtig, um nicht den Kunststoffrahmen des Tablets zum Schmelzen zu bringen.
Beginne seitlich unten am Tablet, erwärme es und setze einen Jimmy oder ein Plektrum zwischen Touchscreen und Rahmen ein.
Trenne zuerst den Kleber am unteren Rand des Tablets auf, dann die beiden seitlichen Ränder. Das Touchscreenkabel befindet sich oben und wird durch einen Schlitz im Mittelrahmen geführt. Es kann leicht abgerissen oder beschädigt werden, wenn das Glas entfernt wird.
Sollte das Glas intakt sein, und es soll wiederverwendet werden, sollte man vorsichtig sein und das Werkzeug nicht tiefer als die Breite des schwarzen Rands einzuführen. Ansonsten riskiert man Schäden am Digitiser, einem dünnen Plastik-Film der auf der Rückseite des Glases klebt.
Der Kleber bleibt eher am Plastik des Mittelrahmens kleben statt am Glas, aber löst sich besser und sauberer vom Mittelrahmen, wenn man ihn an einem Punkt abhebt. Das reduziert auch das Risiko den Digitiser Film zu beschädigen.
