Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 7
The dual rear camera has a beefy bracket that looks like it might offer some bendgate-proofing support for the delicate components. The cameras are additionally secured to the rear case with some foam adhesive to keep things from jostling out of place. These cameras really need to stay put for Portrait Mode and similar features to work their magic. Surrounding the camera housing cover glass, you can see tiny spot welds likely holding the walls of the camera bump to the case.
  • The dual rear camera has a beefy bracket that looks like it might offer some bendgate-proofing support for the delicate components.
  • The cameras are additionally secured to the rear case with some foam adhesive to keep things from jostling out of place. These cameras really need to stay put for Portrait Mode and similar features to work their magic.
  • Surrounding the camera housing cover glass, you can see tiny spot welds likely holding the walls of the camera bump to the case.
Die doppelte Rückkamera hat eine stabile Umrandung, die den fragilen Komponenten wahrscheinlich etwas den Rücken stärken soll.
Die Kameras sind zusätzlich mit etwas Schaumstoffkleber am hinteren Gehäuse befestigt, um ein Verrutschen zu verhindern. Um die Magie wirken zu lassen den Portrait Modus und andere Features korrekt auszuführen, müssen sie wirklich sehr fest sein.
Rund um die Kameraabdeckung außen am Gehäuse sind kleine Schweißnahten, die das abstehende Kameraplateau am Gehäuse befestigen.
