Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Starting on the edge that is opposite the hinge, use the plastic opening tools to pry the back plate away from the computer. Loosen the three non-hinge edges. Leave a plastic opening tool in each corner to ensure that one side does not snap closed before you are done opening the others.
  • Starting on the edge that is opposite the hinge, use the plastic opening tools to pry the back plate away from the computer.
  • Loosen the three non-hinge edges.
  • Leave a plastic opening tool in each corner to ensure that one side does not snap closed before you are done opening the others.
  • DO NOT lift the back plate away from the computer; it is still connected to the motherboard.
Hier Übersetzung einfügen
