Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 6 übersetzen
Schritt 6
Use a plastic opening tool to lift the side of the battery that is closest to the long edge of the computer. As you are pulling the battery away from the computer, unplug it from the side closest to the short edge of the computer. There may be a lot of resistance when unplugging the battery. If there is, try to wiggle the male side of the plug back and forth as you remove it.
  • Use a plastic opening tool to lift the side of the battery that is closest to the long edge of the computer.
  • As you are pulling the battery away from the computer, unplug it from the side closest to the short edge of the computer.
  • There may be a lot of resistance when unplugging the battery. If there is, try to wiggle the male side of the plug back and forth as you remove it.
Hier Übersetzung einfügen
