Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 2
Locate the WiFi module connection on the motherboard by following the grey wire along the bottom. Use a spudger to gently pry it off. Locate the volume control connector on the left side of the motherboard. Gently lift the silver connector off with a pair of tweezers. Continuing up the left side of the motherboard, locate the white power button connector.  Disengage the beige lock on the top of the connector by flipping it up with a pair of tweezers. Gently pull the wire from the connector using the tweezers.
  • Locate the WiFi module connection on the motherboard by following the grey wire along the bottom. Use a spudger to gently pry it off.
  • Locate the volume control connector on the left side of the motherboard. Gently lift the silver connector off with a pair of tweezers.
  • Continuing up the left side of the motherboard, locate the white power button connector. Disengage the beige lock on the top of the connector by flipping it up with a pair of tweezers. Gently pull the wire from the connector using the tweezers.
  • Continuing along the top of the motherboard, disconnect the white LCD connection by disengaging the beige lock and pulling the wire out with tweezers.
Hier Übersetzung einfügen
