Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 3
Continuing to the right along the top of the motherboard, the next wire connects to the motherboard in two places. First, gently lift pry off the gold connector on the right with a pair of tweezers, then use the tweezers to disengage the brown lock on the black connector to the left. Use the tweezers to gently pull out the wire. The final black connector is located on the right side of the motherboard. Disengage the brown lock and pull out the wire with tweezers. The final black connector is located on the right side of the motherboard. Disengage the brown lock and pull out the wire with tweezers.
  • Continuing to the right along the top of the motherboard, the next wire connects to the motherboard in two places. First, gently lift pry off the gold connector on the right with a pair of tweezers, then use the tweezers to disengage the brown lock on the black connector to the left. Use the tweezers to gently pull out the wire.
  • The final black connector is located on the right side of the motherboard. Disengage the brown lock and pull out the wire with tweezers.
Hier Übersetzung einfügen
