Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 5
Depending on the new drive's model, the bezel on your old drive may not transfer to the new one. The bezel is not strictly necessary, and the drive will probably work fine without it, but you should transfer it if you can in order to ensure proper alignment with the case.
  • Depending on the new drive's model, the bezel on your old drive may not transfer to the new one. The bezel is not strictly necessary, and the drive will probably work fine without it, but you should transfer it if you can in order to ensure proper alignment with the case.
  • Remove the 4 Phillips #00 screws from the top of the optical drive.
Hier Übersetzung einfügen
