Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
You will see two tabs towards the bottom of the back cover. Move the tab positioned on the right side to the right. You will know this has been done correctly when you can see the red surface beneath the tab. You will see two tabs towards the bottom of the back cover. Move the tab positioned on the right side to the right. You will know this has been done correctly when you can see the red surface beneath the tab. You will see two tabs towards the bottom of the back cover. Move the tab positioned on the right side to the right. You will know this has been done correctly when you can see the red surface beneath the tab.
  • You will see two tabs towards the bottom of the back cover. Move the tab positioned on the right side to the right. You will know this has been done correctly when you can see the red surface beneath the tab.
Hier Übersetzung einfügen
