Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove rectangular rubber tops with a spudger Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops. Remove plastic edge covering with the blue plastic opening tool.
  • Remove rectangular rubber tops with a spudger
  • Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
  • Remove plastic edge covering with the blue plastic opening tool.
  • Remove two 4.63 mm PH#1 screws located under plastic edge covering.
Hier Übersetzung einfügen
