Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
Pull the air filter from the housing. Remove the air filter housing using a 8 mm socket. Disconnect the two fuel lines from the carburetor using a narrow, flat-head screw driver.
Removing the Carburetor
  • Pull the air filter from the housing.
  • Remove the air filter housing using a 8 mm socket.
  • Disconnect the two fuel lines from the carburetor using a narrow, flat-head screw driver.
  • Disconnect the throttle linkage from the carburetor.
  • Lift the choke linkage out of the housing, and then pull the carburetor from the housing.
Hier Übersetzung einfügen
