Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 4
Remove the four screws holding the diaphragm cover plate, and then remove the plate. Remove the diaphragm and its seal from the carburetor. Remove the screw holding the float set and needle valve.
Carburetor Disassembly (Lower Cover)
  • Remove the four screws holding the diaphragm cover plate, and then remove the plate.
  • Remove the diaphragm and its seal from the carburetor.
  • Remove the screw holding the float set and needle valve.
  • Be careful to ensure that the assembly does not spring apart as the float set is under spring tension.
  • Remove the float set and needle valve.
Hier Übersetzung einfügen
