Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 8 übersetzen
Schritt 8
Once lifted, you will notice that there are two wires tucked under plastic tunnels on the right side of the fan. Remove these wires. These wires require you to gently pull them out of there tunnel. Once the wires are removed the fan should be removed entirely.
  • Once lifted, you will notice that there are two wires tucked under plastic tunnels on the right side of the fan. Remove these wires.
  • These wires require you to gently pull them out of there tunnel.
  • Once the wires are removed the fan should be removed entirely.
Hier Übersetzung einfügen
