Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly. Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive. Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
  • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
  • Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive.
  • Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
  • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at as low an angle as possible, without snagging it on any of the iPhone's other components.
  • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
  • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strips, and then proceed as instructed below.
Halte die Streifen immer glatt und faltenlos, denn verknitterte Streifen werden sich verkleben und reißen, statt sich sauber herausziehen zu lassen.
Drücke den Akku nicht nach unten, während du die Streifen herausziehst. Wenn du auf den Akku drückst, entstehen Druckstellen , die sich verhaken können und den Kleber beschädigen.
Ziehe langsam die Akkuklebelasche weg vom Akku, in Richtung Unterkante des iPhones.
Ziehe gleichmäßig und halte konstanten Zug auf den Streifen, bis er zwischen Akku und rückseitigem Gehäuse herausrutscht. Das gelingt am Besten, wenn du den Streifen in einem möglichst flachen Winkel ziehst, ohne dass er sich an anderen Bauteilen des iPhones verfängt.
Der Streifen wird sich auf ein Vielfaches seiner ursprünglichen Länge dehnen. Ziehe immer weiter und fasse, falls nötig den Streifen am Akku nach.
Wenn der Akkuklebestreifen bei diesem Verfahren reißen sollte, dann hole das restliche Stück des Streifens mit den Fingern oder einer stumpfen Pinzette heraus und mache mit dem Ziehen weiter.
Wenn einer der Streifen unter dem Akku abreißt und nicht geholt werden kann, dann entferne zuerst die restlichen Streifen und fahre wie im Folgenden beschrieben fort.
