Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
Lift the case from the bottom side. NOT the side with the hinges. When you feel resistance, do NOT keep lifting or you will damage the housing. Once you feel resistance, gently pull the case towards you. (away from the hinges.)
  • Lift the case from the bottom side. NOT the side with the hinges.
  • When you feel resistance, do NOT keep lifting or you will damage the housing.
  • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
  • Remove the case.
Hier Übersetzung einfügen
