Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
This is the battery.   For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in. Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal. Remove four J1 Philips screws.
  • This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
  • Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal.
  • Remove four J1 Philips screws.
  • Remove one J1 philips screw.
  • Do not mix these screws up. If you put the longer screw where the shorter screw belongs, you will damage the shield around the keyboard.
  • Lift the battery slightly using your plastic opening tool.
  • Do not lift the battery out all the way, as it is still connected to the motherboard.
  • Do NOT puncture or deform the battery or it may catch fire or even explode.
Hier Übersetzung einfügen
