Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the batteries from your controller (if installed). If you do not have a TR8 screwdriver, the bit can be found in the 64-bit driver kit. Remove the screw under the battery cover label. To do this, puncture the label where it is marked. It is located roughly in the center of the battery bay on the controller. Remove the side trim from the controller, along with the 4 TR8 screws. Set the trim and screws aside somewhere safe.
Disassemble the controller (Part 1)
  • Remove the batteries from your controller (if installed). If you do not have a TR8 screwdriver, the bit can be found in the 64-bit driver kit.
  • Remove the screw under the battery cover label. To do this, puncture the label where it is marked. It is located roughly in the center of the battery bay on the controller.
  • Remove the side trim from the controller, along with the 4 TR8 screws. Set the trim and screws aside somewhere safe.
Hier Übersetzung einfügen
