Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 6 übersetzen
Schritt 6
Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable. Use the tip of a spudger to flip the "lever" of the ZIF connector (left side in first photo) on the hard drive cable. The connector does not come off, see next instruction. Gently pull the yellow sensor bracket cable out of the ZIF connector (to the right, in the second photo).
  • Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable.
  • Use the tip of a spudger to flip the "lever" of the ZIF connector (left side in first photo) on the hard drive cable. The connector does not come off, see next instruction.
  • Gently pull the yellow sensor bracket cable out of the ZIF connector (to the right, in the second photo).
  • Use the flat end of a spudger to pry the hard drive cable up off the sensor bracket to which it is adhered.
  • Remove the adhesive backing from your new hard drive cable, stick it onto the sensor bracket, and connect the sensor bracket cable.
  • Many fixers cover the length of the thicker cable in the pair with sections of electrical tape on both sides because it can rub the tiny ridges inside the aluminum case causing a short to the case itself or simply breaking the connection.
Die Front(sensor)klammer könnte bei deinem Ersatzteil mitgeliefert worden sein oder nicht. Falls nicht, musst du die alte Klammer an deinem neuen Kabel anbringen.
Verwende die Spitze eines Spudgers, um den "Hebel" am ZIF-Verbinder (links im ersten Bild) am Festplattenkabel zu öffnen. Der Verbinder kommt noch nicht heraus, siehe den nächsten Punkt.
Ziehe behutsam das gelbe Sensorklammerkabel aus dem ZIF Verbinder. ( Nach rechts, siehe zweites Bild)
Verwende das flache Ende eines Spudgers, um das Festplattenkabel aus der Sensorklammer, an der es befestigt ist, zu hebeln.
Entferne die rückseitige Klebeabdeckung von deinem Festplattenkabel, befestige es auf der Sensorklammer und verbinde das Sensorklammerkabel.
Viele Reparierer bekleben das dickere Kabel der beiden auf voller Länge auf beiden Seiten mit einem Stück Isolierband, da es sich an den Graten am Aluminiumrahmen scheuern kann. Dadurch kann ein Kurzschluss entstehen, oder einfach die Verbindung unterbrochen werden.
