Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 6
Use a PH0 Philips head screwdriver to remove the 9.0 mm screw connected to the CPU Fan. Once the screw is out of the CPU Fan, then remove the two other 9.0 mm screws indicated. Once the screw is out of the CPU Fan, then remove the two other 9.0 mm screws indicated.
  • Use a PH0 Philips head screwdriver to remove the 9.0 mm screw connected to the CPU Fan.
  • Once the screw is out of the CPU Fan, then remove the two other 9.0 mm screws indicated.
Hier Übersetzung einfügen
