Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
Using your metal pry tool, slowly pry the two halves apart by gently moving your tool around  the laptop .  Once all the way around the top  and bottom half will separate. When pulling the laptops apart be careful to hold them together at first due to the sensitive ribbon cable inside.
  • Using your metal pry tool, slowly pry the two halves apart by gently moving your tool around the laptop . Once all the way around the top and bottom half will separate.
  • When pulling the laptops apart be careful to hold them together at first due to the sensitive ribbon cable inside.
  • Use your metal pry tool again to push the ribbon holding clip up and remove the ribbon cable.
Hier Übersetzung einfügen
