Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
In the following steps, you'll be cutting through the adhesive securing the back cover. The adhesive is laid out as seen in the first image, which shows the inside of the cover after it has been removed.
  • In the following steps, you'll be cutting through the adhesive securing the back cover.
  • The adhesive is laid out as seen in the first image, which shows the inside of the cover after it has been removed.
  • As seen from outside the phone, you'll be slicing through the adhesive in the areas shown:
  • Thick portions of adhesive
  • Thin areas of adhesive
  • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
In den folgenden Schritten wirst du den Kleber entfernen, welcher die Rückabdeckung am Gerät befestigt.
Der Kleber ist wie im Bild 1 befestigt und zeigt die Rückabdeckung von innen nachdem sie entfernt wurde.
Von außen betrachtet durchschneidest du folgende Bereiche vom Kleber:
Bereiche mit dickem Kleber
Bereich mit dünnem Kleber
Vermeide es, in diesem Bereich zu hebeln oder zu schneiden, da du sonst das Kabel des Fingerabdrucksensors beschädigen könntest.
[* black] In the following steps, you'll be cutting through the adhesive securing the back cover.
[* icon_note] The adhesive is laid out as seen in the first image, which shows the inside of the cover after it has been removed.
[* black] As seen from outside the phone, you'll be slicing through the adhesive in the areas shown:
[* red] Thick portions of adhesive
[* orange] Thin areas of adhesive
-[* yellow] ***Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.***
+ [* yellow] ***Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.***
