Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard. Use an opening tool as a wedge between the front and back panel to pry open the front panel.
  • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
  • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
  • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
  • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
  • Flip the keyboard over so the keys are facing up.
  • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
Hier Übersetzung einfügen
