Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver. Use the plastic opening tool to remove the back cover from the laptop. Be aware that static discharge can cause damage to sensitive electrical components within the computer.  To avoid this you can wear an anti-static wrist strap.
  • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
  • Use the plastic opening tool to remove the back cover from the laptop.
  • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
Hier Übersetzung einfügen
