Zum Hauptinhalt wechseln
Removing iPad 3 4G Front Panel
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 153 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 3
Removing iPad 3 4G Front Panel: Schritt 0, Bild 1 von 3 Removing iPad 3 4G Front Panel: Schritt 0, Bild 2 von 3 Removing iPad 3 4G Front Panel: Schritt 0, Bild 3 von 3
  • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
  • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
  • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
Hier Übersetzung einfügen
