Zum Hauptinhalt wechseln
Removing iPad 3 4G Front Panel
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 153 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 8
Removing iPad 3 4G Front Panel: Schritt 0, Bild 1 von 3 Removing iPad 3 4G Front Panel: Schritt 0, Bild 2 von 3 Removing iPad 3 4G Front Panel: Schritt 0, Bild 3 von 3
  • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
  • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
  • The adhesive is very strong, and some serious force may be required. Work carefully.
  • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
Hier Übersetzung einfügen
