Zum Hauptinhalt wechseln
Removing iPad 3 4G Front Panel
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 153 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 20
Removing iPad 3 4G Front Panel: Schritt 0, Bild 1 von 3 Removing iPad 3 4G Front Panel: Schritt 0, Bild 2 von 3 Removing iPad 3 4G Front Panel: Schritt 0, Bild 3 von 3
  • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
  • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
Hier Übersetzung einfügen
