Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 7 übersetzen
Schritt 7
Make sure all the cables and connectors are clear of the board, and use the flat edge of a spudger to gently lift the bottom of the motherboard. The narrow part of the motherboard is very fragile. If it starts to bend when you lift, stop and make sure there isn't anything holding the board down. The board should lift up without any resistance. Holding the wide part of the motherboard near the SIM card slot, carefully slide the board toward the bottom of the phone while lifting it out of the phone.
  • Make sure all the cables and connectors are clear of the board, and use the flat edge of a spudger to gently lift the bottom of the motherboard.
  • The narrow part of the motherboard is very fragile. If it starts to bend when you lift, stop and make sure there isn't anything holding the board down. The board should lift up without any resistance.
  • Holding the wide part of the motherboard near the SIM card slot, carefully slide the board toward the bottom of the phone while lifting it out of the phone.
  • Remove the motherboard.
  • Try to keep the phone flat with the battery facing up after you remove the motherboard, as the front-facing camera can fall out of the phone case very easily.
  • When reinstalling the motherboard, move all the cables and connectors out of the way of the board and make sure all connectors are aligned with their respective sockets.
Überprüfe nochmal, ob alle Stecker und Kabel von der Hauptplatine getrennt sind. Hebe dann die Hauptplatine unten vorsichtig mit dem flachen Ende des Spudgers an.
Der schmale Teil der Hauptplatine ist sehr empfindlich. Wenn sie sich beim Hochheben verbiegt, dann halte an und schauen nochmals nach, ob sie noch irgendwo festgehalten wird. Die Platine sollte sich ohne Widerstand hochheben lassen.
Halte den breiten Teil der Hauptplatine in der Nähe des SIM Einschubs fest und schiebe die Platine zur Unterkante des Smartphones, während du es gleichzeitig aus dem Smartphone heraushebst.
Entferne die Hauptplatine.
Achte beim Einbau der Hauptplatine darauf, dass alle Kabel und Stecker aus dem Weg sind, und dass alle Stecker genau auf ihre Anschlüsse passen.
[* black] Make sure all the cables and connectors are clear of the board, and use the flat edge of a spudger to gently lift the bottom of the motherboard.
[* icon_caution] The narrow part of the motherboard is very fragile. If it starts to bend when you lift, stop and make sure there isn't anything holding the board down. The board should lift up without any resistance.
[* black] Holding the wide part of the motherboard near the SIM card slot, carefully slide the board toward the bottom of the phone while lifting it out of the phone.
[* black] Remove the motherboard.
+[* black] Try to keep the phone flat with the battery facing up after you remove the motherboard, as the front-facing camera can fall out of the phone case very easily.
[* icon_reminder] When reinstalling the motherboard, move all the cables and connectors out of the way of the board and make sure all connectors are aligned with their respective sockets.
