Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
The following steps instruct you to use heat to soften the glue securing the battery. A safer alternative is to inject a solvent, such as iFixit adhesive remover, between the battery and rear case to dissolve the adhesive. Reheat the iOpener in the microwave for 30 seconds. Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than 30 seconds.
  • The following steps instruct you to use heat to soften the glue securing the battery. A safer alternative is to inject a solvent, such as iFixit adhesive remover, between the battery and rear case to dissolve the adhesive.
  • Reheat the iOpener in the microwave for 30 seconds.
  • Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than 30 seconds.
  • Place the heated iOpener in the center of the back of the iPad. Let it sit there for 90 seconds to soften the battery adhesive.
  • Move the iOpener to the right (away from the rear-facing camera), and let the iOpener sit for another 90 seconds.
  • Finally, move the iOpener to the right-hand edge of the iPad for 90 seconds.
  • The iOpener may cool significantly between sittings—if it does, reheat for another 30 seconds between each position.
In den folgenden Schritten sollst du den Kleber am Akku mit Wärme aufweichen. Eine sicherere Alternative dazu ist die Verwendung von iFixit Klebstoffentferner zwischen Akku und rückseitigem Gehäuse, mit dem du den Klebstoff auflösen kannst.
Erwärme den iOpener wieder für 30 Sek. in der Mikrowelle.
Denke dran den iOpener nicht zu sehr zu erhitzen. Warte mindestens zwei Minuten, bevor du den iOpener wieder erwärmst, und lasse ihn nie mehr als 30 Sekunden in der Mikrowelle..
Lege den erwärmten iOpener in die Mitte der Rückseite des iPad. Lasse ihn dort 90 Sekunden lang liegen, um den Kleber am Akku auzuweichen.
Verschiebe den iOpener dann nach rechts (weg von der Rückkamera) und lasse ihn wieder 90 Sekunden lang liegen.
Schiebe ihn zum Schluss auf den rechten Rand der Rückseite und lasse ihn wieder 90 Sekunden lang dort.
Der iOpener kann sich dazwischen merklich abkühlen. Wenn das so ist, musst du ihn erneut 30 Sekunden lang erwärmen.
