Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 6 übersetzen
Schritt 6
Remove the battery from the iPhone.
  • Remove the battery from the iPhone.
  • If your replacement battery came in a plastic sleeve, slide off and remove the sleeve before installation.
  • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
  • Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess.
  • Adhere the battery, disconnect it, and continue reassembling your device.
  • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
  • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
Entferne den Akku vom iPhone.
Sollte dein Ersatzakku in einer Plastikhülle geliefert werden, entferne zuerst die Plastikhülle vom Akku, indem du die Hülle vom Flachbandkabel abziehst, und setze erst dann den Akku ein.
Wenn dein neuer Akku keine Klebestreifen hat, benutze diese Anleitung, um die Klebestreifen zu ersetzen.
Führe einen erzwungenen Neustart nach dem Zusammenbau durch. Das kann einigen Problemen vorbeugen und macht die Fehlersuche einfacher.
[* black] Remove the battery from the iPhone.
[* icon_reminder] If your replacement battery came in a plastic sleeve, slide off and remove the sleeve before installation.
[* icon_reminder] If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
[* icon_reminder] Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess.
[* black] Adhere the battery, disconnect it, and continue reassembling your device.
[* black] If your new battery doesn’t have adhesive preinstalled, refer to [guide|103936|this guide|new_window=true] to replace the adhesive strips.
[* black] Perform a [guide|97575|force restart|new_window=true] after reassembly. This can prevent several issues and simplify troubleshooting.
