Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 4
If you look tward the mesh and the circuits you will see that it is held by 4x #0 Phillips screws. Carefully remove these and the entire cap will come from the board. There are 3 sets of wire, 1 per condesnser. You will notice that they are pointed sideways making this microphone a side condenser and not a face pointed one. If you look tward the mesh and the circuits you will see that it is held by 4x #0 Phillips screws. Carefully remove these and the entire cap will come from the board. There are 3 sets of wire, 1 per condesnser. You will notice that they are pointed sideways making this microphone a side condenser and not a face pointed one.
Removing the Mic condenser from the Mic Mesh
  • If you look tward the mesh and the circuits you will see that it is held by 4x #0 Phillips screws. Carefully remove these and the entire cap will come from the board. There are 3 sets of wire, 1 per condesnser. You will notice that they are pointed sideways making this microphone a side condenser and not a face pointed one.
Schaue nun in Richtung des Filter-Gewebes. Hier siehst du vier #0 Kreuzschlitzschrauben. Entferne diese vorsichtig, damit sich das Filter-Gewebe entfernen lässt. Nun kannst du die drei Kabelsets sehen, jeweils ein Set pro Kondensator. Sie zeigen zur Seite, daran erkennt man, dass es ein omnidirektionales Mikrofon ist. (kein Richtmikrofon)
