Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 4
Now you are able to reach behind the logic board to disconnect the cable running to the power board. The connector has a small tab on the back that needs to be pressed for the connector to be pulled out.
  • Now you are able to reach behind the logic board to disconnect the cable running to the power board.
  • The connector has a small tab on the back that needs to be pressed for the connector to be pulled out.
Jetzt kannst du das Versorgungskabel hinter dem Logic Board ablösen.
Um den Stecker abziehen zu können, musst du an ihm eine kleine Lasche drücken.
