Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 4
Remove the metal plate and be careful because the 2 Phillips screws are fixed to long plastic tubes that may crack when you apply too much torque Behind the metal plate there are 3 Phillips screws I highly recommend magnetic Phillips screwdriver with long thin neck for this step
Remove stand stem
  • Remove the metal plate and be careful because the 2 Phillips screws are fixed to long plastic tubes that may crack when you apply too much torque
  • Behind the metal plate there are 3 Phillips screws
  • I highly recommend magnetic Phillips screwdriver with long thin neck for this step
  • Tilting mechanism will be revealed
Hier Übersetzung einfügen
