Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 5
The tilting mechanism can be easily slide out when you gently push on the plastic lock clamp situated between/below the 2 bolts Also remove the two long Phillips screws that are below the tilting mechanism to loosen the monitor's plastic back Also remove the two long Phillips screws that are below the tilting mechanism to loosen the monitor's plastic back
Remove tilting mechanism
  • The tilting mechanism can be easily slide out when you gently push on the plastic lock clamp situated between/below the 2 bolts
  • Also remove the two long Phillips screws that are below the tilting mechanism to loosen the monitor's plastic back
Hier Übersetzung einfügen
