Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 7
Before we can remove the monitor's plastic side frame we have to disconnect the control panel It is connected with single flat ribbon cable that is connected in clamp connector Use a screwdriver to push on the clamp to open it and loosen the ribbon cable
Disconnect control panel
  • Before we can remove the monitor's plastic side frame we have to disconnect the control panel
  • It is connected with single flat ribbon cable that is connected in clamp connector
  • Use a screwdriver to push on the clamp to open it and loosen the ribbon cable
  • Carefully remove the ribbon cable using a little force. You can wiggle the cable a little.
  • WARNING: try not to touch the monitors electronic to prevent any electric discharge.
Hier Übersetzung einfügen
