Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
Screw open the 2 top screws located at the red arrows. Use a magnetic tip for easy retrieval. Use the door panel removal tools to pry it open from its 4 brackets. Disconnect the battery at this point if you haven't done so.
detach the OEM head unit
  • Screw open the 2 top screws located at the red arrows. Use a magnetic tip for easy retrieval.
  • Use the door panel removal tools to pry it open from its 4 brackets.
  • Disconnect the battery at this point if you haven't done so.
  • Slowly remove the head unit from its enclosure and detach the cables.
  • Power, speaker output and steering wheel control.
  • USB input
  • antenna input
Hier Übersetzung einfügen
