Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 4
Use a Spudger to gently pry the battery connector from its socket on the motherboard. This will keep the Joy-Con from powering on during the repair. Use caution while working around the vibration motor cable that runs close to the battery connector. If you are replacing the battery in a right Joy-Con, you will also need to work around an antenna cable during this step. Use caution while working around the vibration motor cable that runs close to the battery connector. If you are replacing the battery in a right Joy-Con, you will also need to work around an antenna cable during this step.
  • Use a Spudger to gently pry the battery connector from its socket on the motherboard. This will keep the Joy-Con from powering on during the repair.
  • Use caution while working around the vibration motor cable that runs close to the battery connector. If you are replacing the battery in a right Joy-Con, you will also need to work around an antenna cable during this step.
Benutze einen Spudger, um den Akkustecker behutsam von der Platine zu lösen. Das wird verhindern, dass der Joy-Con während der Reparatur angeschaltet wird.
Sei vorsichtig, während du in der Nähe des Vibrationsmotors arbeitest, der sich in der Nähe des Akkusteckers befindet. Wenn du den Akku in dem rechten Joy-Con austauschst, musst du in diesem Schritt auf das Antennenkabel darin aufpassen.
