Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
Use the spudger tool to pry off the red plastic corner cap. Remove the LED headlight casing by pulling up on the casing and out on the corner cap at the same time. Remove the LED headlight casing by pulling up on the casing and out on the corner cap at the same time.
  • Use the spudger tool to pry off the red plastic corner cap.
  • Remove the LED headlight casing by pulling up on the casing and out on the corner cap at the same time.
Verwendeeinen Spudger, um die rote Kunststoffeckkappe abzuhebeln.
Entferne das Gehäuse der LED-Lampe, indem du gleichzeitig am Gehäuse nach oben und an der Eckkappe nach außen ziehst.
