Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 6
Use the spudger to detach the orange drive belt compartment from the vacuum. Remove the orange drive belt compartment from the vacuum by lifting it upwards.
  • Use the spudger to detach the orange drive belt compartment from the vacuum.
  • Remove the orange drive belt compartment from the vacuum by lifting it upwards.
Verwende den Spudger, um das orangefarbene Antriebsriemenfach vom Vakuum zu lösen.
Entferne das orangefarbene Antriebsriemenfach aus dem Staubsauger, indem du es nach oben hebst.
