Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard. Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
  • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
  • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
  • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
Hier Übersetzung einfügen
