Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Using a Phillips #000 screwdriver, remove the screws found on the four corners of the back of the device. The device pictured is extremely damaged.  A normal device should not appear as bent and broken.
  • Using a Phillips #000 screwdriver, remove the screws found on the four corners of the back of the device.
  • The device pictured is extremely damaged. A normal device should not appear as bent and broken.
  • The screws are very small and may require some patience to get a proper grip.
Hier Übersetzung einfügen
