Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 4
Use a Phillips #0 screwdriver to unscrew the three 3.5mm screws in the bottom portion of the phone and put them to the side. Use a spudger to pry the plastic bit off. Be warned, it will pop out and might fling itself when you attempt to pry it out. Use a spudger to pry the plastic bit off. Be warned, it will pop out and might fling itself when you attempt to pry it out.
  • Use a Phillips #0 screwdriver to unscrew the three 3.5mm screws in the bottom portion of the phone and put them to the side.
  • Use a spudger to pry the plastic bit off. Be warned, it will pop out and might fling itself when you attempt to pry it out.
Hier Übersetzung einfügen
