Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 3
Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly. Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive. Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
  • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
  • Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive.
  • Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
  • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at as low an angle as possible, without snagging it on any of the iPhone's other components.
  • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
  • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strips, and then proceed as instructed below.
Versuche, die Klebestreifen glatt und faltenlos zu halten, da verdrehte oder verknitterte Klebestreifen zusammenkleben und reißen werden, statt sich sauber herauszulösen.
Außerdem solltest du den Akku nicht herunterdrücken, während du die Klebestreifen herausziehst, da sonst die Klebesteifen hängen bleiben und reißen können.
Ziehe die Lasche eines Akkuklebestreifens langsam vom Akku weg zur Unterseite des iPhones.
Ziehe gleichmässig und mit konstanter Spannung bis der Streifen zwischen Akku und Rückgehäuse herauskommt. Am Besten ist es, den Klebestreifen in einem möglichst flachen Winkel zu ziehen, allerdings musst du darauf achten, dass er nicht an anderen Bauteilen des iPhones klebenbleibt.
Der Klebestreifen wird sich auf ein Vielfaches seiner ursprünglichen Länge ausdehnen. Falls nötig, kannst du den Streifen näher am Akku nachfassen.
Falls der Klebestreifen bei diesem Vorgang reißt, musst du versuchen das Ende mit den Fingern oder mit einer stumpfen Pinzette zu fassen zu bekommen, damit du weiterziehen kannst.
Falls einer der Klebestreifen unter dem Akku reißt und nicht mehr herausgeholt werden kann, versuche die restlichen Klebestreifen zu entfernen und mache dann wie unten erläutert weiter.
