Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 21 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 11
These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery. Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery. Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
Battery connector information
  • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
  • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
Diese Bilder zeigen, wie der Akkustecker unter dem Logic Board aussieht. Benutze sie, um den Stecker sicher abzutrennen.
Beachte, dass der Akkuanschluss durch freie (Cantilever-)Federn am Logic Board gegen die Kontakte gedrückt wird. Da sowohl das Logic Board als auch der Akku verklebt sind, musst du ein dünnes und flexibles Werkzeug zwischen die Kontaktpunkte schieben, um den Akku abzutrennen.
